Disables the ability to overwrite 802.1p priority values for a given set of ports.
| port_list | Specifies a list of ports or slots and ports to which the parameters apply. |
| all | Specifies that 802.1p replacement should be disabled for all ports. |
| qosprofile | Disables 802.1p on a QoS profile. Note: If this
option is not specified it will disable dot1p replacement for
all qosprofiles.
| qosprofile | Specifies the QoS profile number. |
N/A.
The dot1p replacement feature is disabled by default.
Beginning with ExtremeXOS version 11.4 on the 1 Gigabit Ethernet ports, 802.1p replacement always happens when you configure the DiffServ traffic grouping.
The following example disables 802.1p value replacement on all ports:
disable dot1p replacement ports all
This command was first available in ExtremeXOS 11.0.
The qosprofile keyword and qosprofile variable were added in ExtremeXOS 16.1.
